5 GT Turbo In-tank fuel pump for R5
marc k
Hi all
Does anyone know if any of the clio veriants, in-tank fuel pump that will fit in a Renault 5's fuel tank?
Car has a clio 172 engine installed and i'm not happy with the current gt turbo fuel system setup of external pump pulling fuel from top of tank.
Regards
Mk1 clio tank fits apparently, not tried myself.
Tbh, id just keep stock gtt setup, use oem pump as lift to a 1.5ltr swirl pot and a main pump to suit. I have no issues on efi with the same setup.
Thanks Brigsy. I was hoping to avoid fitting a swirl pot but looks like the way forward.
What way does the system work does the pump supply the carb or does the fuel tank sender unit supply it, my pump works out of the car and relay clicks when ignition is on but when I bridge the wires with all in the car I get nothing, cheers
