ferswin
Well had the car for 5 weeks now, was Tony and Haz old car.
Since than I have been busy:-
Changed heater motor
Fixed heater fan switch
Changed all leather seats for mint ones
New starter motor
Gear linkage repair
Fixed dodgy door hinge
Proper deep clean inside (was a dust bowl!)
Changed rattling rear pads and new pad fitting kit
Fixed the violent boost cut off (new engine loom)
Fitted a dump valve
Decresed boost to 14 from 16psi (car has done 156k miles!)
No piccies at the moment but will be taking loads of photo's when the fun stuff starts happening, quite soon I hope!
Changing engine for this:-
with 5th/6th injectors
Restoring sub frame and new bushes
Fixing rust on rear arch sill and front turret
Full blow over respray
Hi spec brakes with 320mm discs
Prima front bumper
FMIC
Azev A 17" black wheels.
If i come into any money would like to fit a proper alarm and Gaz coilovers but see how things go got plenty to get on with for now :calm:
New starter motor
Gear linkage repair
Fitted a dump valve
Prima front bumper
FMIC
