Brigsy
Media Mogul. Instagram legend.
Updates - efi conversion in progress. Mock up stage
Last view of the old setup
Efi inlet, vw coilpack for wasted spark and dizzy blank fitted
Trigger wheel and crank sensor fitted - not welded as looking at 60-2 flywheel options
Made a start on routing wiring into the engine bay
Ended up whipping the dash off its clips to aid access
32mm hole drilled to suit - have a rubber loom bung to suit
Wiring in engine bay ready to route/drill more holes
