exhaust
gbuk
need a mid section for the chammy,
good used or s/steel system,
is the centre the same on chammy and cab/hatch?
im sure they are, its the chammies rear end ie backbox is different, it has a longer pipe thats connects the two ;)
centre section is identical
rear section connecting pipe is identical too, only the tailpipe on the very end is different
i got a section (the bit behind the back box) from a cabby that's new if it is the right bit?
that's the bit i got. will photo it tomorrow. It's new, came with the car as an extra. How soon do you need? Can bring to the next meet...
its for the chammy,blowing around the middle box,no real rush as its tempry sealed with paste
how much do you want for it,and where are you located,cheers
