Espace 2.0l t
gtpower
Ok so just bought an espace privilege 2.0 t
Soon will be putting engine in my twingo 2 gt
What gearbox can I use because it has auto box and any info if anyone has done this before 1000000855.webp
You'll need to redrill the block to use a 5 speed. that will allow it to drop in the standard twingo 2 engine bay.
Or fit a meg box and modify the chassis and subframe
its pretty involved to fit, not a direct bolt on. you need a whole host of parts to make it work
I'm still reading everybit slowly to help
Have mechanical back ground so should be able to fit most parts my self with abit of luck but I do have help if needed
I find reading hard so taking me longer
Would you be willing to write a list of parts I need I could pay for them
Thanks adey
That looks like a Phase 1 Espace which will most likely have the s2000 engine ecu. Is that compatible to your Twingo?
I don't know I thought you could run a turbo ecu on a turbo engine if same brand just drive slow to tunner then they can change it I don't know just learning as much as can
Thanks adey
i think there is a list in the build thread, it was a while back so i cant remember it all to list now tbh.
try this vid, i talk through some of it.
