Steve Swan
Result....
Very Good result then.Thanks, we was a 10th away from the Class lap record around Silverstone GP in the wet !!!
Certainly be checking the cooler hoses from now on. The cooler and hoses were fitted new last year after we dropped a valve.
Yeah, remember about future classic
Any help /advise just shout, happy to help.
We are back in July Chris.Annoyingly I am away this weekend, would love to pop to brands and watch a 5 race on track.
Have a great weekend
Any ideas why?brake pedal going to floor at probably 120mph !!!!
Pad knock off… was very aggressive through suttee and clear ways on the kerbs.Any ideas why?
No never had this with the AP’s.Have you had this issue before?? R8 are bad for knock off as they have a floating rear hub which wobbles about a bit. The pads knock off as the disc is moving sideways and pushes them, but this should only be by the amount of play in the hub, which in your case R5 should be minimal.
I ask, as a mate with an early Darrian T90 (with Imp Kingpins) was getting bad Pad knock off on the Crail stages. This was a new issue to him, but was actually caused by a growing fatigue crack in the stub pin. This resolved itself when the front wheel finally sheared off completely! Thankfully there was no damage to the occupants and the car survived with just some bruises.
Every failure I have had, definitely had warning signs which I misunderstood or ignored, but were obvious after the damage was done and I had thought about it.
Don't want to spoil your day, but don't want your car spoiled either, or you for that matter.
Also congrats on the results.......
Have a similar issue fitting rear discs to midgets to much flex in the half shafts causes pad knock off.No never had this with the AP’s.
Real issue with previous willwoods and learnt to left foot brake before corner to bring pedal back.
Appreciate the feedback steve
I’m pretty certain it was me trying to hard and taking liberties with the kerbs.
The pedal comes straight back with a dab so definitely pack knock off.
No issues yesterday in the rain and brakes were spot on keeping away from apexes![]()
Saw this recently. Martin Brundle in a stock car pumping the brakes to combat pad knock-off. Very cool pedal work.Real issue with previous willwoods and learnt to left foot brake before corner to bring pedal back.
Sorry Mark, missed this.Have a similar issue fitting rear discs to midgets to much flex in the half shafts causes pad knock off.
Have I missed that this is a new brake set up? Or something else changed?
