Custom Solid Lower Engine Mount
  • Start date Start date
Status
Not open for further replies.
A
Anonymous
The 'yes' list..
JonnyC
v6Max
Big Peaches
ColinG
Maybe's..
Peter255
Miguel 4747
Hey
Some of you may have seen my post in the Tuning forum discussing the availability of up-rated engine mounts for the V6.
http://www.v6clio.net/forum/viewtopic.p ... highlight=
The engine Mounts (3 in total) are for sure one of the weaker points of the drive train, the standard mounts feel extremely soft giving sluggish throttle response and increasing the chances of suddenly shocking the drive-train with a huge thump when you get onto the power suddenly.. Im sure lots of you have felt this!
The lower engine mount sometimes referred to as a pendulum mount, controls the swaying motion of the engine from the bottom of the motor to the rear subframe. When this is solid, it limits the movement, resulting in sharper throttle response, because there is effectively less 'slack' in the drivetrain, definitely worth doing!
Heres a comparison picture of the Standard and Custom Lower Mount
Anyways 'TRW1' has said that he will look into the possibility of a group buy for these parts, as they are custom made, having a multiple order for say 5+ should make it a lot more viable for the manufacturer to produce.
If your interested just let me know so that we can get an idea on numbers
Thanks
Jonny
Ahhhhhh so that's what's causing it
There has been talk of around £75 but this is very much an estimation at this point..
There will be more accurate pricing soon
Thanks
Jonny
Scott is sending off an original mount again so that we can get a price for production. I'll update when we have news.
definately in!!!! i hate the jerking of the standard one when on and off the throttle
let me know a price
With it being the lower mount i would say its going to be pretty simple to change.. Although im sure someone knows from experience!
I would say bottom cover off, support the engine, swap the mounts replace the cover and away you go.. Shouldn't be much more than 30mins IF its easy to get to
Thanks
Jonny
I presume it's the engine side of the mount that is different then is it? Mine has the Mk2 s/f but with Mk1 engine yet still used to run the Mk1 mount......
Very interested....
The amount of engine movement is getting on my nerves...
We do not have a MK2 mount to use for measurements so I cannot pursue that further unless someone can supply one.
MK1 mount has gone to be re-measured/priced.
Will let you know price when I have it. This may be slightly more than anticipated owing to VAT that wasn't applicable on mine.......
Status
