Brigsy
Media Mogul. Instagram legend.
Going back to post above i wasnt happy with the compbrake top mounts as the small spacers were missing. Looked at all options and oem are pretty expensive and no camber adjustment. To fix current ones spacers and bearings around £100 from compbrake. As i love destroying my bank balance i looked at the PMS meg2 top mounts and went that route.
Ordered and arrived next day. Sexy
The engineering is superb. One of the best aftermarket top mounts ive ever seen. Leagues ahead of compbrake, bc, and the ast ones i have on the kangoo.
Main reason i went for these is they do not raise the rideheight as designed not to.
PMS vs oem.
Compbrake in comparison add 10-15mm to rideheight which is sub standard on oem shocks/lowered springs..ok with coilovers maybe.
As with all pms products it fits exactly how it should.
Set negative camber as much as available on standard diameter springs as they hit the turret if you go for more. Its -2deg so thats fine for what i need.
Fitted and back on its wheels. Taxed and on the road.
Straight down for geo and dialled in 10 mins of toe overall. Camber -2 deg as above and castor is around 5.4. Thrust angle is now zero.
Looks much better with everything new!
Now drives excellent. No knocks or nothing, as straight as a die. Turn in is awesome, and its absolutely planted on the back roads like a good r26 should be!
Also improved the overall cabin rattles and creaks as ive adjusted the boot latch to pull boot closed tighter. The boot used to creak when going over bumps etc, and now no noise with it adjusted. Done the same to the blue meg years ago and its like night and day.
Took it out for some datalogging on the evening. Started raining so didnt go too mad.
Noted coolant temps when cruising are slightly higher than expected between 90-92deg. In comparison megs are usually in the 80s unless your driving quick.
The bumper under tray is missing so airflow is not forced through the rad pack so id say thats the issue. Done the same on the trophy and refitted it and dropped a few degrees off temps. Ill bang a new thermostat in just incase.
Washed the bird s**t off it on Sunday and it rained as expected.
Progress has been a little slower than expected but were back road legal and only a few jobs left. Get the snagging finished and get a trackday done soon hopefully!
Thanks for reading.
PMS vs oem.
Thanks for reading.
