Forgot to say had a carry on with the radiator. Rad was leaking so changed it for used oem that i had in stock. Id done due dilligence and filled it with water to check for leaks and it didnt appear to leak? Flushed cooling system throughly and a load of shite came out. Filled with coolant and a fountain of type d comes out of one of the top bars on the rad!!
Dug out the aftermarket meg rad i used on the kangoo and fitted that and filled with type d and bled. Leak free. Id like oem rad ideally so will try and sniff a new one out.
Took it in for geo yesterday. Was miles out as expected, interestingly thrust angle was a mile out so we slackened rear beam bolts off and adjusted it to get it right.
action shot
Compbrake mounts work nice on oem dampers/cooksport springs. Max of -2deg negative camber and slightly more positive castor. Ten mins of toe out overall.
Birds eye view
Works again and drives great like a good r26 should. Happy Brigsy
Also had aircon regassed, its holding gas and works again. Will see if it lasts.
Needs new tyres on badly as on linglongs..will address that soon and the rest of the snagging.
Thanks for reading!!
