bidderman1969
detailer
personally i'd try one thing at a time as these things tend to work together, so if ones out its easier to eliminate i would imagine
MAP sensor is easy enough to check if you've got a vacuum pump, alternatively you could use the engine as a vacuum source.
At idle you should be about ~35kPA of vacuum (so with the throttle plate shut) - measure the voltage on the back of the plug for the MAP sensor, then as you slowly open the throttle plate the voltage should start to increase until at wide open throttle it should be at its maximum (if i remember correctly the voltage increases as the vacuum decreases - i.e you'll get a low (this is just a random number so dont use it as gospel) 0.5v @ 35kPA and something like 4.5v @ 101kPA (which is wide open throttle - as its atmospheric the engine cant create any vacuum due to the throttle plate being fully open).
<hard sell> Alternatively if you invest in one of my shiny usb diag boxes you'd be able to graph your MAP sensor output vs engine RPM vs throttle position and see if it was responding correctlySame for the lambda (O2) sensor btw as well... you should be able to graph its output and see that its not responsive! </hard sell>
Matt
now changed the cts and lambda but not cured the bouncing idle. i don't know what to do. I'll have to get someone to check it out cause i'm just wasting money replacing stuff that isn't broke.
