This Clio suffers from the usual Renault dropped door syndrome, and does a proper little SAG when you open it off the latch. No-way on this earth I’d live with this, so took a big boy pill this morning
and made a start.
Ordered a couple of sets of new hinge pins off old CGB Bob from eBay:
I know these TORX headed hinge pins well enough now to know that they come off a lot better with a bit of assistance with a couple of Ugga Dugga’s from an impact driver and less chance of the head rounding off. Well this time it helped, but i managed to shear off one pin off just under the head, and another just before it entered the second portion of the hinge.
So it was back to medieval ways, with the lump hammer and punch:
And after a fair amount of beating l, and Heating (gas torch), it started to play ball:
I managed to remove the door:
With the door off, I drilled out the old bushes, and knocked out anything remaining:
New bushes slipped in a treat and with the new pins, will have that door tightened up no end:
When the door was on the table, I managed to get the remaining bottom hinge pin out after some more hammering and heating
But the top hinge pin is just NOT playing ball:
After a few whacks and some
it’s just bent the hinge mounting:
So that’s where I stopped today, before I got the hump, with the door off, but quite far from going back on…
