5 GT Turbo Another Red Renault 5 GT Turbo On It's Way Back To The Road
Gearbox oil sure has a distinctive aroma 😜, just a bit annoying but better now and fixed than on a decent run somewhere in the future 👍
Yes mate, it stinks!
It’s just one of those things. I’ve covered it in some absorbent granules/cat litter type stuff for now. To be honest, it’s less of a pain in the arse than the water leaking in!
I’m just surprised a Renault has held on to that much oil for all these years! 🤣
Thats Dexron III, autobox oil/power steering fluid. Use proper gearbox oil not that when you rebuild it.
Interesting. Are they interchangeable?Thanks for the tip though. I’ll make sure I fully drain it and replace with whatever is recommended 👍🏻.
Actually, maybe the car spat it out! 🤣
Not really. Will it work, yes, is it ideal, no!
Saying that I wouldnt say use recommended oils anyway - old oil specs and tech. Use modern synthetics, 5w50 for engine for this era and 75w80 synthetic for gearbox. Note this is my personal preference, i'm sure others have other opinions!
Great, thanks for the info. 👍🏻
Modern, non hypoid, non bevel drive, use any thin Piss. The lighter the oil the longer the synchros last. ATF has enough EP properties to look after the gears. To be fair a good 75 synthetic would be a better technical solution.
There's no shearing forces to contend with so big EP number not reqired.
Thanks for this, Steve. When I get round to it, I’ll drop the remaining oil and refill with decent quality synthetic 75, as per yours and Dave’s recommendation. I’m pretty sure I’m going to drop the engine before it goes back on the road to give it a once over. Is there anything I should check with the gearbox too, whilst it’s out? Cheers.
If it was quiet and free shifting, then it should be fine. Probably worth doing the driveshaft oilseals (if they are easy to replace) and the shifter oilseal if there is any signs of leaks. That will be on the top of the box, so shouldn't leak anyway, one of the things they got right designwise on newer boxes is to put the holes above the oil level ....
Selector seal is gearbox strip down to fit in jb/jc. Every one ive seen has leaked too, some drippers, some gushers 😆
I've not done a proper update for about a month so here goes....
Floor flange prepped and painted
New inner sill made and tacked in place
Working my way between welds, trying to keep it from warping.
Welds dressed back
Now to clean up the front jacking point area, which initially looked bad.
Turned out ok In way better condition than the other side was.
Hydrate 80 for now and I'll come back to that.
A bit of prep work to the outer sill. To be honest, this sill was poor compared to the other, even though I bought them as a pair. I spent quite some time trying to improve it, and although it's still not great, it's passable....and hidden behind the kit.
Marked out and cut
Back to the front jacking point
Primed & seam sealed. I reckon I went a bit heavy with the seam seal.
Coat of stone chip
Replaced this section between coats of paint
Right, after prepping the inside of it, the jacking point is ready to go on.
Welding upside down, on your back, with sod all room....is crap.
Welds cleaned up
Inner sill cleaned up
Hydrate everything
Almost ready for the outer sill.
