21 turbo
-Jo-
Gonna build another renault,
the 21 is for sale (compleet as a car or in parts)
in parts:Engine and spec’s:
-Subframe, reinforced
-Subframe bushes 1 year old
-GrN engine mounts
-J7R752 original cup engine, 1 build by Achterberg, Rebuild after 2 races by Raepers/Borremans. After a managment failure , demaged a piston and liner and bought the engine like that.
-Compleet rebuild in 2007 by myself, used parts:
-balanced crank/flywheel
-cup rods
-Wossner Cup pistons/rings/gudion pins
-Steel liners, custom made by Raepers
-uprated oilpump
-new sump
-new strengt.plate
-cup head with bigger valve’s and 3angle valvesittings, cup valve springs
-pipercam 276? (atm fitted with the techniprofile stage 4 cam from Andy)
-Siemens Deka 575cc injectors
-Fuelpress.regulator 10 bar, double membram rallysprint
-NGK irridium sparkplugs
-matched inletmanifold with headports
-Magnecor leads
-GM 3 bar mapsensor
-55mm tb, custom trottlepositioner
-cup plenum
-new waterpump, new alternator 105a
-GrN startermotor
-AP racing 4 paddle clutch + cup cover and bearing
-Original cup ic with cup hose to plenum
-custom radiator + 2 spalfans 10”
-original cup bend intercooler to turbo
-all hoses: samco
-garret GT3071R custom build with GT2871R compressor
-extreme wastegate V-band
-Forge actuator, comes with extra spring (high pressure)
-std exh. Manifold
-cup metal watertubes (other material then std) with S/S heatshield (downpipe)
-Oilfeed hose (turbo) custom made for GT series
-Mocal 30 row oilcooler
-3” downpipe with flex and Vbands
-refurbed gearbox, 12.000 km
ECU: std with 2 chips supplied (techniprofile cam and pipercam)
Obvious fitted with new bearings,gaskets,hg,timingbelt and tensioner.
Every 3000 km oilchange/filter (Castrol Edge 10w60)
Probl. Forgotten some parts…
Testdrive poss. as long the engine is in the car.
For all the above: 6000 € (no offers)
shell parts avaible
hispec breaks (17" conversion)
gaz suspension
compleet stock lots off new parts, GrN , cup ect., UK shell (rolling).
10.000 all incl. (car + stock), i'm open for serious offers.
Running a soft setup atmo; 311 hp/500 Nm
Heavy set up: 345 hp/556 Nm
Will translate part of the stocklist this afternoon, to much to write down, endless list.
---------- Post added at 10:51 AM ---------- Previous post was at 10:47 AM ----------
same as in the vid, nothing changes since 19/10/2009
http://www.youtube.com/user/jo21turbo?gl=NL&hl=nl#p/u/4/kxla_Bb6lh4
some stock parts:
1 rolling Shell, dash, clutch and mechanisme, sub, breaks ect still attached. (ex craig)
1 set red doors (4)
1 set iceberg grey doors (4)
1 set tungsten doors (4)
3 bonnets (2xwhite,1 red)
3 boot’s
Engine looms: 10
Dashlooms: 8
17” racing dynamics ( ex lee baby blue) never fitted them
17” momo’s
17” BK wheels
17” Mak wheels
4 tyres yokohama parade spec2 , like new (17”)
4 tyres yokohama A539 , like new 17”
16” borbet RS17
Std ph1 15”
Std ph2 15”
9 sets skirts
4 engines
4 camshafts std
Liners; 16
Pistons; 20
Crank; 4
Flywheels: 8
Std ic’s: 6
Leather: 2 sets
Master and slave cilinders: 6
Subframes: 4
Turbo’s: 4
GrN enginemounts: 6 new
GrN starter motor: 1 new
GrN pedal box: 2 new
Inlet manifold cup; 1 new
Inletmanifold std: 3
Injectors 357: 4 sets
Injectors 804: 4 sets
Injectors 802: 2 sets
Relais and switches: 3 plastic bags full
Exh manifold s/s custom: 1
Exh manifold nikasil T4 ex wastegate (cup/rally manifold): 1
Vitaloni cup mirrors + doorplates: 1 set new
Cup primary shaft: 1 new
Driveshafts: 12
Gearboxes: 3
GrN hubs front, incl bearing/disc: 1 set new
GrN hubs rear, incl bearing/disc: 1 set new
GrN torsion bars: 6 +6 blanks new
Rear axle like new, incl hubs break lines: 1
Rear axle: 2
Fuelpumps: 5
10 boxes with small parts.
lots off body parts
way to much to write down
Jo - I cant afford to buy. But I note you said building another renault. Another 21 turbo ?
Hi mate,
i cant sell seperate engine parts as i want it to sell as 1, plug and play in another car.
And,
if i cant sell the engine/car i cant do the other project. So i must keep the engine togheter. I still have the twinplate clutch and vernier to fit... When the other project is a no go then i'll do another upgrade on my own engine.
