Is this cos the 172 is a one-hit phase of the cam on-off, and the 197 is variable phasing with a PWM valve as opposed to the on-off like the 172?
Exactly that. I think the setting i have been told to use will be the same as if you straight fitted the 197 cams in the 172 head.
