started work on the clio today, have a list of faults that need sorting.
First the immo sometimes cuts in and stops the car starting. Im sure its the immo relays as im getting a solid red light indicating that the key and code are fine but there is another issue stopping the car starting. Will clean up all the relays and go from there but could possibly be a uch issue and or earth issue
Possible uch fault, drivers window works in reverse of the switch, passenger does nothing no clicking of relays though it has power to both switches. Funny thing is even with CLIP plugged in the drivers runs in the opposite direction its supposed to when actuated and for some reason the passenger side isnt even listed to be actuated?!?!
Indicating briefly illuminates the fog light on the dash clocks, so either the uch or dodgy earth.
Ive re positioned the battery and moved the air filter to behind the light, Car sounds bonkers like it has vtec! needs 2 front tyres, exhaust needs re positioning as there is a rattle on a heat shield and its out of line on the bumper. Gear stick needs re positioning as its too far to the right currently. Seats need replacing as they are quite worn but a friend locally has a full cup interior. Will need a general tidy up, there have been stickers on it at some point and both rear arches are starting show signs of corrosion creeping in. Dephaser is also noisy, but it goes really well stops very well too so with a few bits and some time thrown at it itll be a great car again. On the hunt for suspension, wheels and tyres and then possibly some brembos to stop it even better.
Ill try and get some pictures tomorrow.
