Got a set to go in my lads twiglet, know a few people personally who are running them and seen a few on Facebook and forums running them. Unless you are going for stupid big power they wouldn't put me off.
Spoke to a guy by me who was building an engine for someone who insisted on eagle rods and the guy said about Chinese rods but he wanted eagle so they arrived from America still in their original box with made in China on it!!
So the Block, Head and crank are all ready to go. Didn't need much, just a hone, polish the crank and 4 thou skim on the head.
And these arrived today.
I was really wanting 8.5:1 compression ratio and I think they have come through as 9.0:1. But may be a good thing as it brings a limit to it and it'll be perfectly adequate for a road car.
I've also bought an intercooler core to make my own!
24"x8"x3.5" rated to 600bhp so I'll give it a go.
Forgot I've got an alloy meg rad and fan pack coming too and my R26 gearbox is currently being rebuilt.
I've booked a place on the clio's and coffee at Efi parts on the 23rd of this month, just to check all is OK with the map but it's looking a bit tight but possible.
Don't really need to drop it but just thought you wanted that as an ideal figure.
Don't quote me on this but the 225 gasket is about 0.8mm thicker than the standard one and the 250 is about 0.5mm thicker again.
Was speaking to Mike tanski a while ago and as a rule of thumb on a 4 pot 2 litre an extra 0.8-1.00mm drop compression by roughly '1'
Also when did you order the core from and when? Heard there might be an issue with their main supplier in the UK? Apparently their site has been down for a while?
I followed the guide and it cost me a lot of time because I had to re-do the fan loom. The larger plug is easy you just pull the retainer out and swap the wires around.
The last plug (small) is a little different and needs to be cut and soldered.
Coming back to this, I am about to do the conversion. Can you post a pic of your UPC wiring like this please? This is the current Clio one on mine, i'd like to see your post-conversion picture if poss.
I've been labelling up the Meg loom ready to do the pin change.
Vibrant UK has gone into liquidation, so luckily they have an order with Vibrant in Canada and managed to add mine to the order and I should have it in around a week or so.
I have an issue with my ring gaps, Top ring is far too big where the 2nd ring is pretty good, I'm thinking the rings are wrong, fitted an original over 100k ring as a test and it was 5 thou smaller than the new top ring??
So a few more bits,
I managed to fit the crank tonight,
Still waiting on some rings which is starting to drive me mad as I'm getting impatient.
