Haven't updated this in a while,
So Basically after nearly a 1000 miles of Loving my clio, I had a noisy tappet.
Strange so removed the Cam cover to find.. The cam had picked up in the head. Also the tappet was sticking in the head. Silicone had been used to fit the cam cover which goes rock hard with the heat from the turbo. There was plenty of oil about so looking to the silicone to be the culprit!!
So, the car is now laid up at work. I've picked up another engine with low compression on no.1 so hope the head is all good! But to be on the safe side I'm going to save up and forge it.
Plan is 8.5:1 compression
Using Iasa or Iapel pistons
Not sure what rods yet probably Catcam, king race bearings, arp rod and main bolts.
Not sure if I'll go with doing the head at the same time or later. See how we go!
