Hi, anyone ever did it here and it worked for him? I want to start this project following the guides from retro renault. I would appreciate any help. Where should I get the parts from? Why can't I open the images in the guide? It says I have no permission.
I'm not going into too much detail here but if people need any more info just ask and i'll add it in. The renault diagnostic port is an open collector output and we need a simple adapter board to connect this to a USB serial cable and the XR25PC software (or alternatives) The components...
This guide will show you how to make a full USB cable using one of our adapter PCB's. You can also make your own. Things you will need Retro-Renault Adapter Kit FTDI USB TTL Cable 3.3V of 5V Renault OBD-II to 12 Pin Adapter (not the moulded design) Soldering Iron, Drill, Screwdriver...
gives me an error: Oops! We ran into some problems.
You do not have permission to view this page or perform this action.
I will try contacting him, thanks.
