looch":2isw36zl said:Great read pal! [smilie=yay.gif]
Lankan":19j897q6 said:Must have been a long day, but sure worth it in the long run..........
Question: Why is the Phase 1 ECU still in place and not the Phase 2 ECU from the same car that you got the engine from?
Okay, understand Jon. I wasn't aware of this when we touched base re the RTI issue you were having, so curious as to whether this may have anything to do with having the "Ph1 ECU with a hybrid loom"? In any case if this can be fixed during the remap then it will no longer be an issue.taipan":10e7kui7 said:Lankan":10e7kui7 said:Must have been a long day, but sure worth it in the long run..........
A very good and valid question!! Something Chris pondered as well. I think the long and short of it was it's less complex (read less expensive) to splice the ph1 loom for the requirements of the ph2 engine than bin the ph1 ECU/loom and run the ph2 ECU and loom.
Retrospectively it would have been money thrown away anyhow. Had I opted for the Ph2 ECU and loom install I would have effectively been paying for that to run the dash, a/c and other non-engine functions as the new ECU is going to be running the engine. In other words, I've come to the right conclusion albeit using the wrong method!!! lol
Seems more like an injection issue to me. When you lift off at hight RPM (equals high speed?) The injection is shut off after a little delay. The ECU is programmed for a lot of reciprocating mass therefore the injection probably "reengages" only slightly above 1000 RPM which is enough to "catch" the engine. With the TTV flywheel however I expect the engine to decelerate a lot faster which probably doesn't give the ECU time enough to prevent it from stalling. Increasing the reengagement RPM by a few hundred should solve it in my opinion unless it's caused by the overall tune which might not be the best. I don't think it's the throttle because normally the valve should go to a save idle position which shouldn't make it stall. however I can be totally wrong.taipan":33vzxgms said:2) The return to idle is spazzing out now the TTV is installed leading to stalling if, when coming to a stop from high speeds (motorway exit junction roundabouts for instance) you don’t downshift through the gears with throttle blipping. I should say at this point that the car is running a Ph2 engine with a lot of extra inlet air on a ph1 ECU and hybrid loom and so it's already pretty grumpy. Having spoken to others that have had the TTV installed they report no ill-effects, so don’t read this and necessarily decide against the TTV; the benefits - particularly against the ph2 OE DMF - far outweigh the unique downside I have. Chris says he sees RTI problems a lot with aftermarket supercharged cars where the engine isn’t used to the load of the supercharger at idle and it’s a relatively simple thing to solve. Worse-case scenario he’ll have to run an independent throttle controller to give him full access.
Lankan":3hehassd said:Good to hear that the cause for the stalling you experienced has now been confirmed.
So do I understand correctly that the Adaptronic ECU will be the only controller in play, and that the standard ECU will be removed?
What changes to the wiring harness/loom are necessary to make this transition?
taipan":3fw429pz said:Without wanting to get egg on my face, I imagine the car should be comfortably faster than a standard ph2. Not night and day of course, but with the power up a bit, weight down by quite a bit (in comparison to a standard ph2) and the ph2 gear ratios it'll all add up. Anyhow, enough of Vee racing. When are we going to have my daily vs your daily???![]()
Chris asked whether I wanted pops and bangs mapped in on the over run. Guess what I said....... lol
V6 2HOT":3mtc7rr1 said:I guess you said no, I want my car to be as discreet as possible in tune with the other mods!!
