williams 3
backflipper
Do the subframes from any other models fit on the williams 3? By fit I mean are the exact same? A mate reckons he bent his and is need of some help!
Cheers lads
all clio subframes will fit.
The other williams ones are the same. The 16v iirc is just the same as the non 16V ones.
The only difference is some extra triangular bracing and radiator support bit
the wishbones are the difference as far as I remember
the subframe on the clios is totally different at the radiator
