Wheel offsets 21 Turbo v Megane 225
Tony Smith
Just wondered if the 7 x 17" wheels I've taken off my 21 Turbo are going to be same/similar offset and bolt pattern as later Renaults such as Megane 225 or Laguna Coupe?
The PCD for a Laguna III is 114mm & offset is determined by specification.
The 225 should have the same 108mm PCD & centre bore, but I not sure on the offset but I think it's about 50mm.
