Wheel bolts.
H
Howard
Just checked main dealer for parts for my phase 3 turbo:
Wheel bolts....no longer available.
Stub axle.......no longer available.
Dirt shield......no longer available.
Anyone know to any new old stock since it looks like sourcing from breakers.
Wheel bolts are M14x1.5 and the threaded section is 25mm long. I forget the taper angle on the seat.
Either way there's a new set on eBay.
The stub axle will be easy enough to source from someone on here second hand, the dirt shield I don't know which part your referring to, do you have a better description, where and what does it shield?
The other parts
Parts
The other parts
Thanks for the info lewis. Dirt shield is the main dealers description for the inner wheel arch cover.
---------- Post added at 10:42 PM ---------- Previous post was at 10:18 PM ----------
How many wheel bolts do you need?
Hi Dave, will need 5 bolts.
I have the wheel arch cover. Which side?
---------- Post added at 12:04 AM ---------- Previous post was at 12:02 AM ----------
Infect I have the bolts somewhere as well if saves already sorting you some out I'll leave it to him.
If you have the lot mate, go for it. Saves me a job lol
Wheel bolts & cover
Thanks lewis. Nearside cover and 5 bolts required. Could you message me with further details. These are the bits I can't get from the main dealer. Already posted that I'm after a tungsten nearside wing. All this due to a garage 'mechanic' not tightening front alloy wheel!
