hi!
I have a trouble with a Megane R26 that comes from an unknown tuner. They messed up the wastegate pre-load and now we have some problems to adust at the OEM values.
Only way you would be able to reset it to standard value is to set the boost DC to zero and datalog how much boost it produces which indeed should be around .38bar.
Easier option is to count the threads from a non fiddled wastegate, i can do this for you tonight if you like
