G
Guest
heya guys,
my valver will start and idle at around 1100 - 1500 revs or it will start, fire up then die straight away!
i have adjusted the throttle cable under the bonnet (hence why it idles high!)
but everytime you floor it in first then clutch and pull to a stop, it just dies! :evil: :mad:
is it something to do with the ISCV? if so where is this located and what can i do about it?
if i hold it at any revs it fine, i can hold it on the bite up too 850 rpm on the clutch if i want to and its fine! its only when im nowhere near the accelerator pedal that it does it and its so annoying to have to keep re-starting especially when the immobiliser is having an eppy fit! :evil:
please help! *cutes puppy eyes look*
matt x
matt x
