v6 trophy still won't start...Going to push it in lake soon!
boccarp
where is the cam sensor located? I have now cleaned and flowed the injectors (perfect), Perfect impression, perfect spark, replaced crank sensor, it has wicked spark in all6 ports, new plugs, fresh vp100 fuel. Noid light shows the injectors only firing one pulse then nothing even if you continue to crank. Ok ecu problem?
Did you try seeing will it attempt to fire with a spray of easy start. ?
Seems like you have everything else except fuel.
