Tyres advice
David Bailey
Bought some r888 fitted fine 235/40 91y but after a track day they have started catching the coilovers springs should I have got a smaller tyre what size am I after on a 18 inch r26 rim any help would be appreciated
Sent from my SGP311 using Tapatalk
I will have a look and see if I have enough room I'm sure there should be if not will go down the new tyre route thanks for the advice
Sent from my iPhone using Tapatalk
Simulate spacers with some washers between the nuts and wheel. You can drop it on the floor so the suspension compresses and even rolling back and forth a few metres to settle the suspension. Use ONLY for assessing clearance. DO NOT drive the car normally like this.
Remember that fitting spacers would usually require longer wheel bolts unless you're down at 3mm spacers or smaller.
