5 GT Turbo Track set up ARB
Clarkey
Looking to upgrade the front Anti Roll Bar set up for next year.
Any ideas or upgrades available to prevent roll.
We already run 400lb springs, I don't want to go any more as starting to suffer with traction coming out of corners.
You can get a thicker arb (25mm??) off possibly a mk1 megane coupe from memory that pretty much goes straight on with minor trimming using the megane bushes and brackets. Alastair Brown had one on his rally prepared gt which worked well- give him a shout he should be able to point you in the right direction
Epic drawing, to scale and evryfink
We took it off as the car was sooo low it scraped on the trailer when loading. But it was SO low the exhaust came in to the cabin through the floor and out the nsr quarter so anything higher than stupidly low should be OK.
Dave..... please tell me someone younger that Robin did this drawing!
But yes the Fuego we had, had a second roll bar clamped to the first
