DaveL485
Staff member
The onset of winter and is crap weather has seen my car running too cold, to the point its now not getting out of "cold" engine mode and the resulting fuel economy is horrific! It was OK through the summer so i've drawn the conclusion the best place to start is the thermostat (P/N 9617028380).
Anyone replaced one? Any tips? I should be able to access it through the normal engine cover without taking the 4,328 screws and fittings out to remove the main trim bits. Probably.
Looks like 4 retaining bolts (yellow) and is the red marked one the bleed screw?
[album]20000[/album]
Thanks in advance
Thanks in advance
