These are deffo genuine ones, they have the logo at the bottom outside corners, came in a Renault box/bags with the correct part number on, and an instruction sheet lol
if you need to do some "swapping" with items to find out what needs doing with the little jobs, feel free to pop over matey and can swap bits and bobs with mine to double check
Hey neal, I'm struggling to source the subframe cage nuts in your report, part number 7703044037. Went to renault, that part number is for some plastic cage nuts. Could you point us in the right direction please?
Just reading this thread again about the sills, think on p21. & u say u cut it back level to the inner sill which the outer is spot welded to. And any higher would cut off the quarter panel spot welds, which i agree not good right.
But what if you had to repair the whole sill or the part above these quarter panel spot welds??
E.g if you look at that 1st pic of yours, where the bit bulges out with the holes in (just under the bottom of the door).
You'd have no choice but to just do it and grind off the spot welds. If you were careful you could probably drill and puddle weld the new sections in the same places.
Yeh that was what i was thinking to drill/grind out the spot welds and then re weld the sills to the quarter. & hopefully not changing the shape of the quarter panel/bodyline. Luckily not happening to my car :lol:
But was wondering if you wanted to refresh the whole seal and couldn't grind out those spot welds, your buggered.
would you know how to sort the immobiliser on a 2000 megane 1.4. its stuck on with red light flashing. you can get me on [email protected] if you have any ideas
