The last of my bits turned up today so i got them fitted. Wiring finished and the temp switch for the rad fan fitted. Tested it at idle and allowed it to warm up and cool down over a few times over. Working great so really happy with that.
Then on to the oils. Engine oil dropped, filter changed and new oil in. Gearbox oil was another story, took about 2 hours to gravity feed it into the box. Still filled up and all good.
Right onto the test drive, its pokey and goes very well doesn't feel too bad at all. Pulls very cleanly in all 4 gears and is probably at the limit of the chassis and brakes that are on there. Only down side is it runs very hot. No leaks, no over pressurising runs very well, no smoke and no mixing of oil but when cruising along it gets hot enough to keep the fan running, so it 92+ degrees. If you pull over and idle itll drop back down on the fan. Anyway a quick chat on the drive with the mechanic neighbour and hes going lend me his timing gear and comp tester again just to set everything up. Ive just twisted and turned the dizzy till it started and left it there. His suggestion was the timing being out followed by carb jetting thought the carb looks to be an renault 8 item. I decided to do a quick search of a french renault 8 website and low and behold the first hit that came up for "température du moteur" was a chap with an r8 whos car was running very hot, fitted a new rad, cowling and electric fan only to find his timing the issue. Maybe and fingers crossed the engines are just a little sensitive to timing.
7 Mile test drive and it hasnt blow up yet.
