Hi Mate,Hi, mate!
Have you test this clutch set? How it works?
It can do it in 2nd and 3rd too uphill at low speed while i am trying to release the clutch slowly, but first gear can be heard easily.Only first gear? Doesnt that suggest gearbox rather than clutch? The clutch should do it in all gears, it doesnt know what gear the car is in...
It's a Brand new Clutch matt.The Helix clutches are renowned for failing prematurely so could be faulty.
Ive seen them fail with light use. @Mark Davis had no end of issues with Helix.
What is CG , do you have a link please.Avoid like the plague, nothing but trouble and appalling customer service. They take zero interest in helping you and just place the blame on you as the driver/customer.
Go to someone like CG on the other hand and it’s a completely different story. They couldn’t be more helpful and their aftercare is excellent.
The clutch is not slipping, however i didn't put heavy load yet, around 7 psi , 50% percent throttle and locked the rpm till 5k now , it spins the wheels so it is not slipping the clutch.
It do this sound while releasing the clutch slowly on first gear.
However i am happy to know what other options rather than Helix clutches.
