Update time I guess.
Had a few bits needing doing before Spa a couple weeks back, mainly maintenence stuff really.
Had new front calipers fitted along with some plain Brembo discs and some RST3 up front with some RS44s on the back, couple with Ti shims and Endless fluid im properly chuffed with how great the brakes are now, Zero issues with fade or heat so the ducting definitely seems to be helping.
Also had some AR1s fitted onto my 17x9 track wheels, 255 front and 225 rear, very impressed with how good the tyres are. Near enough a DZ03 for half the cost. Just a bit pants in the cold and damp as I found out early at Spa, particularly under brakes.
Had my front right AST damper fail as well so that put a bit of a downer on the day as it basically meant I had no damping on that corner which really wasn't confidence inspiring particularly on the fast stuff. Still managed Iver 200 miles on track and a 3 min lap with a wounded car though. Plenty to come off that next year with a few tweaks to my setup and working dampers.
That's about it really, few small plans for the winter but not much. Cage, Xenons, lightweight battery and possibly Abs removal then get a full seasons worth of trackdays out it next year.
20170926_134019 by
Jamie Atkinson, on Flickr
20171003_172601 by
20171003_123346 by
20171003_112443 by
20171003_112410 by
20171001_164619 by
20171001_082129 by
XSP_6918 (2) by
XSP_7499 (2) by
XSP_7860 (2) by
XSP_8108 (2) by
XSP_8028 (2) by
Also sorted some brake ducting out, could do with tidying up the intakes on the grill but function over Form haha, certainly helps with Temps
20170831_140030 by
20170831_140021 by
20170831_123651 by
20170831_121127 by
