Retro-Renault Identification
Status
Not open for further replies.
The T.I.B.
is rarely serious
credits: bncrew for illustrations
VIN Plate
Found on the bonnet slam panel or inside the driver's door jamb
As you can see the model type and paint code can be read straight off. For example, my R19 16v in Tungsten Grey would have a model type L53D and paint code 608.
Model Types
Fairly self explanatory other than to say that commonly the first letter denotes the body type (e.g. C for hatchback), the middle number the model (e.g. 53 for a R19) and the final letter the version (e.g. D for 16v in the case of the R19)
If you're ringing Renault for a price and they ask for a registration plate, this is so they can look up the model type and find the correct parts. If you know the model type then just tell them this in the first place!
Some common examples:
R19 16v hatchback: C53D
R19 16v Chamade: L53D
R5 GTT: C405
Clio Williams: C57M
A comprehensive list can be found [iurl=http://www.retro-renault.com/forums/general/11029-retro-renault-identification.html?garpg=2]here...[/iurl]
Gearbox Codes[imgr]http://i73.photobucket.com/albums/i233/tominbristol/04012008373.jpg[/imgr]
Gearbox codes can be found on a stamped tag attached to the top of the box (see image, right)
Common gearbox codes:
JB3-051: R19 16v phase 1
JB3-083: R19 16v phase 2
JC5-053: Megane 2.0 16v, Clio Williams
Here is an interesting comparison of the R19 16v ph1, ph2 and megane 16v 2.0 gearboxes: http://www.retro-renault.com/forums/subscribers-area/9584-gearbox-ratios.html
Paint Codes
When choosing paint for a touch-up it is important to bear in mind that not only is your car's colour likely to have weathered but it could be one of a variety of shades from the factory according to paint batch etc.
Therefore it is recommended to compare your paintwork directly with a colour chip provided by a paint manufacturer e.g. Lesonal etc. Match to an area such as the roof which is least likely to have been replaced or resprayed in the past.
Metallic shades are assumed to be based upon two coats of basecoat then clear lacquer.
Some common paint codes:
449: Sports Blue / Williams blue (note Williams 1 & 2) / Le Mans blue
432: Monaco Blue (note Williams 3)
495: Gordini Blue
608: Tungsten Grey (e.g. R19, R5, R21, etc)
963: Brooklands Green (e.g. R19 16v)
[iurl=http://www.retro-renault.com/forums/general/11029-retro-renault-identification.html?garpg=3#content_start]More paint codes...[/iurl]
Renault 19 Phase 1 colour charts [thanks to bncrew]
[BREAK=Model Codes]
Renault 5
C405 - 5 GTT
C407 - 5 1.4 Prima SPI C type engine.
C409 - 5 GTX
Renault 5 1.0 C,TC (B/C400) 1984-86
Renault 5 1.0 C,TC (B/C400) 1986-90
Renault 5 1.1 Campus (B/C40H) 1986-92
Renault 5 1.1 L,TL (B/C401) 1984-86
Renault 5 1.1 L,TL (B/C401) 1984-90
Renault 5 1.1 L,TL (B/C401) 1987-90
Renault 5 1.3 TR (S40F) 1987-90
Renault 5 1.4 Campus (B/C407) 1987-92
Renault 5 1.4 GT Turbo (C405) 1987-91
Renault 5 1.4 GTL (B/C402) 1984-91
Renault 5 1.4 GTS,TSE (B/C40J) 1984-86
Renault 5 1.4 GTS,TSE (B/C40J) 1987-92
Renault 5 1.4 TS (B/C403) 1985-91
Renault 5 1.6 Diesel TD,GTD (B/C404) 1984-86
Renault 5 1.6 Diesel TD,GTD (B/C404) 1987-90
Renault 5 1.7 GTE (C409) 1984-90
Renault 5 1.7 GTX (B/C408) 1984-86
Renault 5 1.7 GTX (B/C408) 1987-90
Renault 5 1.7 GTX (B/C40G/K) 1987-90
Renault 19
B = 5dr hatch, C = 3dr hatch, L = 4 door saloon D = 2 door Cabrio
B531 - 19 1.4 C type OHV engine
B537 - 19 1.4 energy carb model (E6J)
B535 - 19 1.4 energy injec model (E7J)
B53L - 19 1.9 Diesel
B53K - 19 1.9 Turbo Diesel
C53D - 19 16V
C539 - 19 16V CO adjustable non cat
D53C - 19 1.7 8V cabriolet
D53D - 19 16V cabriolet
D53V - 19 1.8 8V automatic cabriolet
D53Y - 19 1.8 8V cabriolet
L537 - 19 1.4
L53A - 19 1.4 RN
L53Y - 19 1.8 RT
L53D - 19 16V
L539 - 19 16V CO adjustable non cat
L534 - 19 Diesel
L53J - 19 Diesel
L53K - 19 Turbo Diesel
Renault 9
Renault 9 1.1 C,GTS,SE (L421) 10/86-88
Renault 9 1.1 C,GTS,SE (L421) 1981-9/86
Renault 9 1.1 C,TC (L421) 10/86-88
Renault 9 1.1 C,TC (L421) 1981-9/86
Renault 9 1.4 GTL,TL (L422) 10/86-88
Renault 9 1.4 GTL,TL (L422) 1981-9/86
Renault 9 1.4 GTS,TSE (L423) 10/86-88
Renault 9 1.4 GTS,TSE (L423) 1981-9/86
Renault 9 1.4 Turbo (L425) 10/86-88
Renault 9 1.4 Turbo (L425) 1985-9/86
Renault 9 1.6 Diesel GTX,TXE (L42D,L42N) 1987-88
Renault 9 1.6 Diesel TD (L424) 1983-88
Renault 9 1.7 GTX,TXE (L42N) 1987-88
Renault 11
Renault 11 1.1 C,TC,GTC (B/C371) 1983-9/86
Renault 11 1.3 C,TC,GTC (B/C371) 10/86-88
Renault 11 1.3 C,TC,GTC (B/C371) 1983-9/86
Renault 11 1.4 TL,GTL,TSE(B/C37A) 10/86-88
Renault 11 1.4 TL,GTL,TSE(B/C37A) 1983-9/86
Renault 11 1.4 Turbo (B/C375) 10/86-88
Renault 11 1.4 Turbo (B/C375) 1985-9/86
Renault 11 1.6 Diesel TD,GTD (B/C374) 1983-88
Renault 11 1.7 GTE (B/C37E) 1987-88
Renault 11 1.7 GTX,TXE (B/C37N) 1986-88
Renault 21
L485 - 21 Turbo Ph1
L48L - 21 Turbo Ph3
Renault 21 1.4 TL,GTL (B48D,L48D) 1986-96
Renault 21 1.7 GTS,RS,TL,TS,TSE (L482,L48E) 1986-5/87
Renault 21 1.7 GTS,RS,TL,TS,TSE (L482,L48E) 5/87-96
Renault 21 1.9 Diesel GSD,SD (B48H,I,L48H,I) 1993-96
R21 1,7i (B/K/L48E) R-Cat (CH/D) 87-93 F3N 722
R21 1,7i (B/K/L48F) R-Cat (CH/D) 87-93 F3N 726
R21 12V 2,0i (B/L48Q/Y) 90-93 J7R 754
R21 2,0i (B/L/K483) 86-93 J7R 750/751
R21 2,0i 12V +4X4 (B/L48R) R-Cat 91-94 J7R 740
R21 2.0i (X48C) R-Cat 90-94 J7R 746/7
R21 4X4 (K483) 90-93 J7R 750/751
R21 TURBO (L485) 88-93 J7R 752
R21 TURBO 4X4 (L48L) R-Cat 91-94 J7R 756
R21 TURBO 4X4 (L485) 91-93 J7R 752
R21/4X4 2,2i (B/K/L48K) R-Cat 87-94 J7T 754/755
Renault 25
Renault 25 2.0 GTS,TS (B292) 1984-93
Renault 25 2.1 Diesel GTD,TD (B296) 1984-93
Renault 25 2.1 Turbo Diesel (B290) 1984-93
Renault 25 2.2 GTS,GTX,TS (B297) 1984-93
Clio 1
3 doors - for 5 doors replace the C with a B e.g. C573 = 3dr, B573 = 5dr
C571 - Clio 1.1 RN/RT (night and day)
C572 - Clio 1.2 RL/RN/RT
C573 - Clio 1.4 RN/RT
C57J - Clio 1.4 phase 3
C57U/C57C - Clio 1.8 RT
C579 - Clio 1.8 RSI
C57D/C575 - Clio 16V/Clio 16V Co adjustable
C57M - Clio Williams
C57L - Clio 1.9 Diesel RN
Espace
ESPACE 2,0i (J636) R-Cat 91-97 J7R 768
ESPACE 2,0i (JE0A02/05) R-Cat 96-99 F3R 728/729
ESPACE 2,0i 2000-1/4X4 (J116) 86-91 J7R 760
ESPACE 2,0i 2000-1/4X4 (J117) R-Cat 86-91 J7T 770
ESPACE 2,2i/4X4 (J/S637) R-Cat 91-97 J7T 772
ESPACE 2,8i/4X4 (J638) R-Cat 91-97 Z7W 712
ESPACE 3,0i (JE0D02) R-Cat 96-99 Z7X 775
Extra/Express
EXTRA/EXPRESS (F40 U/V) 1,4i R-Cac 90-97 E7J 724/720
EXTRA/EXPRESS (F406) 1,2 R-Cac 93-99 C3G 710/712
EXTRA/EXPRESS (F407) 1,4i R-Cac 92-97 C3J 762
EXTRA/EXPRESS (F40S) 1,4i R-Cac 95-99 E7J 770/771
EXTRA/EXPRESS (F40U) 1,4i R-Cac 94-99 E7J 726
EXTRA/EXPRESS 1,4i (F40D) R-Cac 95-99 E7J W728
EXTRA/EXPRESS 1,4i ATR-Cac 95-99 E7J 726/\/773
Kangoo
KANGOO 1,2i R-Cat 98-99 D7F 710
KANGOO 1,4i R-Cat 98-99 E7J 780
Megane
BAOE - Megane hatch 1.4 RT
BA0F - Megane hatch 1.6
BA04 - Megane 1.6 16V
BA08 - Megane hatch 1.9 DTI
EA0H - Megane Coupe/Cabriolet 2.0 16V
BA0H - Megane 2.0 16V
Megane Coupe ph1 1996-1999
DAOF 1.6
DAOG 2.0 8v
DAOH 2.0 16v
DAON 1.9Dti
Clio 2
CB0L - Clio 1.4 16V
CB1C - Clio 172 Mk1
CB0N - Clio 172
CB1N - Clio 172 CUP
Laguna
B56S/B56T/B560/B56Z - Laguna 1.8 8V SPI
B56L/B56C/B56H - Laguna 2.0 8V MPI
B56N - Laguna 2.0 8V MPI
B56D/B56M - Laguna 2.0 16V MPI
B56E/B56R/B565 - Laguna 3.0 V6 MPI
B56F/B562 - Laguna 2.2 D
B566/B569 - Laguna 2.2 TD
LAGUNA 1,8i (B56B) R-Cat 94-98 F3P 720
LAGUNA 1,8i (K56T/Z) R-Cat 96-98 F3P B670/S724
LAGUNA 2,0i (B/K56) R-Cat AT 94-99 F3R 723
LAGUNA 2,0i (B/K56) R-Cat MT 94-99 F3R 722
LAGUNA 2,0i (B/K56L) R-Cat 96-99 F3R-728
LAGUNA 2,0i (B/K56L) R-Cat AT 96-99 F3R-729
LAGUNA 2,0i 16V (B/K56D) R-Cat 96-99 N7Q A700
LAGUNA 2,0i 16V R-Cat 97-99 N7Q 704
LAGUNA 3,0i (B/K56E) R-Cat MT 94-97 Z7X 760
LAGUNA 3,0i (B/K56R) R-Cat AT 94-97 Z7X 765
LAGUNA 3,0i R-Cat 97-99 Z7X 767
LAGUNA 3,0i V6 24V (B/K 56V) R-Cat 97-99 L7X 700
LAGUNA 3,0i V6 24V (B/K 56V) R-Cat 97-99 L7X 701
Master
MASTER 2,2i (RXXA) R-Cat 90-98 J7T 782
Megane
MEGANE 1,4 (BA0E) R-Cat 95-99 E7J 764
MEGANE 1,6 (B/DA0F) R-Cat 95-99 K7M 702/703
MEGANE 1,6 (BA0L) R-Cat 95-99 K7M 720
MEGANE 2,0 (B/DA0G) R-Cat 95-99 F3R 750/751
MEGANE 2,0i 16V (DAOH) R-Cat 96-99 F7R 710
MEGANE ECO 1,4 R-Cat 97-99 E7J 624
...and more
353a - F3p Jb3
353c - F3p682 Jb3
353d - F3p682 Jb3 Eqlvl 210
353f - F3p765 Ad4
453a - F3p Jb3
453c - F3p682 Jb3
453d - F3p682 Jb3 Eqlvl 210
453f - F3p765 Ad4
453h - F3p Jb3
553a - F3p Jb3
553c - F3p682 Jb3
B530 - C1g730
B531 - C1j742
B532 - C3j710
B533 - F2n
B534 - F8q706 Jb3
B535 - E7j742 Jb1
B536 - F2n742 Jb3
B537 - E6j
B538 - F3p Jb3
B53a - E7j
B53b - F3n
B53c - F3n
B53d - F7p704 Jb3
B53e - F2n728 Jb3 Eqlvl 101
B53f - F3n746 Jb3
B53g - E6j Jb1 Eqlvl 510
B53h - C2j776
B53i - No Vin
B53j - F8q742 Jb3
B53k - F8q Jc5
B53m - F2n722 Jb3 Eqlvl 101
B53p - C2j772
B53t - F8q744 Jc5
B53v - F3p765 Ad4
B53w - E7f730
B53y - F3p
B53z - F8q768 Jc5
Courtesy of Chris H, from the old forum plus contributions as below
Also Welkom bij de Renault Tuning Club - 5 Jaar :: View topic - renault software
[BREAK=Paint Codes]
109 = BEIGE ALPAGA
129 = Platin-Beige
139 = CAMARGUE
164 = Toskarna rot
170 = BEIGE
186 = BEIGE HOUBLON
187 = PIERRE DE LUNE
188 = BRONZE 188
189 = BRUN CANELLE
190 = AMANDE
191 = STEPPE
262 = GRIS PLUTON
268 = NOCTURNE
271 = BLEU IRIS
274 = ROUGE
296 = VERT SCARABEE
298 = VERT LICHEN
302 = JAUNE PAILLE
306 = ANIS
308 = BOMBE JAUNE
314 = TERRE DESIENNE
319 = BLANC
327 = ORANGE
329 = BLANC ARTIQUE
348 = Polar-Weiss
355 = BLANC
369 = BLANC
377 = Daytona-Gelb
389 = Arktis weiß
396 = JAUNE CITRON
408 = Lazuliblau
423 = BLEU
426 = BLEU CIEL
427 = BLEU EOLE
428 = BLEU ORAGE
432 = MonacoBlau
414 = Biscaya-Blau
447 = BLEU PRUSSE
449 = Le Mans blau
454 = Agäis blau
455 = Gala blau
456 = BLEU TOBAGO
457 = BLEU OUTREMER
460 = BLEU ROY
468 = Kristall blau
471 = BLEU VOLT471
472 = Twilight Metallic Blue
489 = BLEU MYOSOTIS
494 = BLEU CORFOU
495 = Gordini blau
496 = BLEU CYAN
499 = BLEU COBALT
540 = BLEU DE CHINE
541 = BLEU MANDARIN
542 = GRIS
544 = BLEU TIBETAIN
546 = BLEU IMPERIAL
549 = BLEL ILIADE
565 = GRIS PERLE
578 = ROUGE RUBIS
591 = VERT AMAZONIE
592 = BLEU TIBETAIN
596 = GRIS OTTOMAN
597 = ILLUSION
603 = Vulkan-Grey
608 = Tungsten Grey
612 = GRIS
616 = CRIS OPALE
617 = GRIS PLATINE
619 = GRIS CLAIR
620 = Starlight-Silber
630 = Stein grau
632 = Polargrau
640 = Silber grau
642 = BOMBE GRIS
643 = GRIS BRUME
644 = GRIS
647 = GRIS TITANE
666 = Tauben-Grau
671 = BLEU NYMPHEA
673 = BBE GRIS
676 = Permutt schwarz
688 = GRIS
694 = Magic-Schwarz
698 = BOMBE NOIR
699 = NOIR
701 = ROUGE COQUELICOT
705 = ROUGE
710 = Flamenco-Rot
719 = Rubin Red
727 = Spanish Red
731 = ROUGE ANDALOU
763 = Sienna Red
771 = Brick Red
777 = Persian Red
783 = Bordeaux Red (oder Perlmuttrot)
784 = BLEU ILIADE
799 = Magenta
901 = VERT VERTIGO
903 = ABYSSE
910 = VERT
913 = VERTLAITUE
920 = VERT FJORD
925 = VERT TURQUOISE
926 = VERT EPICEA
931 = VERT TILLEUL
932 = VERT
934 = VERT YANOS
935 = VERT CEDRE
940 = Verona Grün
941 = VERT FIDJI
958 = VERT MELEZE
963 = Brooklands Green
968 = VERT ATLANTIDE NAGRE
983 = Achat-Grün
985 = VERT CORIANDRE
991 = Petrol
995 = VERT JADE
996 = Tundra grün
999 = Tief grün
1203 = NOIR
1204 = CENDRE
1219 = BRUN
1222 = CENDRE CLAIR
1223 = CENDRE FONCE
1602 = ZINC SPRAY
1624 = PP GRIS 16
8439 = BLANC POLAIRE
A17 = JAUNE DE MANILLE
A19 = BEIGE ANGORA
B14 = SR MARRON CALLISTO
B64 = GRIS SIDERAL
B65 = GRIS AGATHE
B66 = CR15 ECLIPSE
B69 = GRIS MERCURE
B73 = CUIVRE NACRE
B76 = ROUGE DE FEU
B77 = ROUGE MARGOT
B79 = ROUGE GARANCE
C66 = GRIS BEIGE
C67 = GRIS OLIVE
C68 = GRIS SHETLAND
C99 = ABSINTHE
DII = BEIGE POIVRE
D12 = NATUREL
D13 = NUAGE
D14 = GRIS CAFE
D30 = JAUNE SOLEIL
D33 = ORANGE MALAGA
D37 = JAUNE AUTOMNE
D38 = ROUGE SANGUINE
D40 = GYPSE NAGRE
D41 = BLEU MARIN
D42 = BLEU NAVY
D43 = BLEU MONDIAL
D44 = BLEU ODYSSEE
D45 = BLEU VIBRATO
D46 = BLEU ANATOLE
D47 = BLEU ORAGE
D48 = BLEU NAUTILUS
D49 = BLEU EGOSSE
D60 = GRIS LUNE
D61 = GRIS TECHNIQUE
D69 = GRIS PLATINE
D70 = ROUGE SYRACUSE
D72 = CASSIS
D73 = ROUGE FLAMBOYANT
D75 = ROUGE VOLCAN
D76 = VIOLET EMPEREUR
D90 = VERT MOUSSE
D92 = VERT OCEAN
D93 = VERT COTTAGE
D96 = VERT GIVERNY
D97 = CUIVRE
D98 = AMAZONE
D99 = VERT CITRON
F42 = BLEU GLACE
F43 = BLEU ENCRE
F47 = BLEU CYCLADE
F90 = VERT ONYX
F91 = VERT RAINETTE
F92 = VERT MOTU
974 = VERT ORION
F96 = VERT SAULE
F97 = LIVE PASTEL
H39 = JAUNE D'OR
H97 = VERT
J47 = BLEU GRIS
143 = BLEU ATOLL
144 = BLEU INTENSE
149 = BLEU PROFOND
191 = GRIS CENTAURE
137 = JAUNE SIRIUS
J41 = BLEU ARTIC
142 = BLEU MENTHE
145 = BLEU DYNAMO
Credits: renault19world.de
Status
