5 GT Turbo Renix ignition module tacho output
Neal R19
Alright all, does anyone have any info about what is the form of the tacho feed from the renix module to the cluster?
On the 19 (and I guess probably others), there's a pink wire that basically goes from one of the pins on the module straight to the dash cluster to drive the tacho.
I need to know what the form of it is. Some sort of square wave? 12V pulses? Some kind of damped sine wave?
I don't have a running Renix equipped car and even if I did I don't have a scope at home!
tbh the info will (or should) all be in the adaptronic documentation but I don't have adaptronic so I don't have that info... and there's no incentive for me to look for it.
Its the same signal as the trigger to the ign coil, there's 3 ign outputs and I use 1/2 for wasted spark. 3 is configured for tacho.
How about I incentivise you with beer? :D
