"Renix" / Flywheel sensing
MakeEverything
Ive had a look at my megasquirt software, and it has a "Renix 44-2-2" flywheel setting for trigger / ignition.
Is this the renault ignition / name of the flywheel?
I may be able to simplify my electronics by removing EDIS, and use the existing flywheel pickup point if it is.
Yer its the trigger pattern for the ph1&2's
Happy Days. Megasquirt supports it as part of the firmware. All i need really is a diagram to figure out how to connect it all, then i can do away with the ford EDIS and Coil Pack and simplify my wiring a little. :biggrin1:
