Haz
A long delay in updates and only get the odd day on the van, with plenty of head scratching too!
First up was adjusting the garage doors, the van can now be worked on indoors, albeit tight
I had returned back to the scrapyard to collect some missing parts. I had overly complicated things mixing and matching so tried sourcing direct fit parts. essentially the blocks are the same but everything else differs with the laguna.
Collected the aircon setup with some loom
The window runners looked tatty
And have manual winders
So picked up some replacements, including some electric, heated mirrors
Door card off
Replacement rail, electric mechanism and mirror fitted
And replacment door cards, tidier with buttons
I swap over the door loom to cater for the additional connectors, they don't plug into the dash loom!
I have a feel about under the dash for the air con connector, thats missing too!
With little to google on these vans besides maintenance, I found another breakers with more selection to work things out. In short, they either come in poverty spec or with the electric pack, the entire van loom is different, with connectors at different points.
I was quite set on the idea of air con and electric windows so proceeded to fully strip another van, the engine age range is 2000-2007, but there is some minor differences 2004 onwards so i stuck with the same age as the luguna stuff.
Back in the garage, the entire engine bay loom out
dash loom back out
And every other bit of wiring including the rear doors
Door card off
dash loom back out
