I sent this info to someone else asking about the car so it would be good to have it on here too
This is the worst bit where the sill has been repaired previously, I think the outer sill is solid but it needs repairing where it meets the inner sill. The bottom of all the doors has rust bubbles this one is the worst
Sorry about the quality on this one. Just showing rust bubbles on the door
Rear drivers side arch is rusty
Rear passenger side arch is rust and it looks like something in the boot caused these dents
The bottom of the passenger rear arch and door has some rust
This is the same door
Front passenger door rust bubbles, the sills look solid
The jacking points are dented but don't look rusty
Inner sill behind the sill repair, this is the worst bit, the rest of the inner sills look fine
The subframe is like new I've fitted new poly bushes and painted the anti roll bar
Some rust in the battery tray area, I over looked this when painting the engine bay.
Stone chips in the windscreen, it'll need a new screen for mot, I forgot about this
I took everything out of the boot and filled it with the good stuff
At the back there are all new bougicord leads, dizzy cap and arm. Brand new oil, brake fluid, 1 litre of gearbox oil to finish topping up the gearbox. I haven't got a complete exhaust that will just go on, I've got parts that oli gave me and a complete r5gt scorpion exhaust which might be usefull
Most of a r5gt loom, a replica r5 phase 1 grill and r5 poly bushes
R5 phase 1 koni suspension set, obviously used, i think the tops need to be swapped to fit this car as I couldn't just bolt them up
Original wheel caps, I've got the steel wheels too
