Having remembered to put the N/S spring pan in the car I went to the Garage. The N/S assembled no problem, so I decided to break out the trammel bar and start primary set up. These simple tools are copies of the original Renault special tooling of the time.
The points fit into the various holes in the shell helpfully provided by Renault for accident repair measurement
Next up a cheapo 26mm spanner ground down and bent for the purposes of castor adjustment
You put one point in the centrepoint hole in the middle crossmember and set the distance from there to one of the 6mm bolts on the bottom balljoint with a bit of manipulation of the adjusters I equalised both sides to the maximum castor setting
N/S finished for now
Same for O/S
Couple general shots of the front end
I then decided to check the rear axle for square. It is not, so that's tomorrow night's job
More soon.....................
