Please do.Can @Adey or @DaveL485 or any of the other management team confirm it would be ok for me to post up extracts from Renault's old solutions de replacement fiches regarding Renault bearings. Back in the 80's-90's when your part number came up as no longer available, with bearings it was possible to look up the solutions Fiches with sizes to cross reference numbers with bearing numbers to see if any other part nos existed for the same bits. In the end the parts manager got fed up of me living in the parts dept and printed off the 7 pages of bearings for me. I have them scanned and saved and can post them up they cover probably from 4CV to 1995???
Go for it. If we get sued, we'll just grass you up and run away.Can @Adey or @DaveL485 or any of the other management team confirm it would be ok for me to post up extracts from Renault's old solutions de replacement fiches regarding Renault bearings. Back in the 80's-90's when your part number came up as no longer available, with bearings it was possible to look up the solutions Fiches with sizes to cross reference numbers with bearing numbers to see if any other part nos existed for the same bits. In the end the parts manager got fed up of me living in the parts dept and printed off the 7 pages of bearings for me. I have them scanned and saved and can post them up they cover probably from 4CV to 1995???
Sounds like a plan then!Go for it. If we get sued, we'll just grass you up and run away.
Steve, Looking over your setup sheets I assume RH is ride height. If so, where do you make this measurement? I'd like to compare my R8 values with Paul's car.The spring has arrived, even though it's meant to be summer.......
It's in and been up and down the road and if you were remotely interested you would have looked at this before when I posted it the first time.
It had too much rear bias and felt a bit odd on the road. flicking it from side to side gave you the sensation it would swap ends , then when you actually got your teeth into a bend it would understeer, this was not the car to give to @paule78 .
Changing the rear springs has produced this sheet with my long suffering Brother in Law sat in the seat for the duration and for the sake of slightly better science
Sorry about the quality of the pic , but you will note several changes, most if not all positive
The Road test revealed a more benign car which is much more neutral, but actually has a better front end. This while not perfect is close enough to return to it's owner for testing and appraisal an no doubt the production of a list of things to do.
This is the reason for measuring things once you have endured the pain of doing it a few times you can get where you want to be much quicker with subsequent attempts. when I first set up my 8 nearly 20 years ago. it took closer to 12 sheets to get something close to this for balance, and if you've read the Dauphine thread ..........Well you know don't you.
If I had not wrong footed myself with the wrong back springs thinking they were the right ones that are in now, then the 2nd sheet would have been the 1st sheet and I would have been a Legend (in my own mind anyway) but this is real life and I'm never that lucky
Definitely not much more soon......... bet you're glad.............
BobSteve, Looking over your setup sheets I assume RH is ride height. If so, where do you make this measurement? I'd like to compare my R8 values with Paul's car.
Steve,@DaveL485 Sounds like a plan. The only ones I can see are the malpassi version, which I don't know anything about, quality etc. Other types aimed at fuel injection which will Feck the Carby in no time at all.
In other news the MK1 throttle linkage is finished
And I don't like it ! it works well enough. I will try it on the motor and see
The Mk2 is cooking away at the mo.
Thanks Steve, that makes sense.It's to do with the position of the mainjet in relation to the laws of Physics. The only time fuel can slip away from the mainjet is under braking. If you leave it standard it runs out of fuel on right-handers I remember.
All these little wrinkles have to be ironed out, before it all works properly.
Ultimately the throttle spindle should be in line with the crank, which it won't be, but it is the lesser of two evils.
Straightaway you realise that the people who design cars,are not as stupid as they seem, well sometimes anyway.....
