The spring has arrived, even though it's meant to be summer.......
It's in and been up and down the road and if you were remotely interested you would have looked at this before when I posted it the first time.
It had too much rear bias and felt a bit odd on the road. flicking it from side to side gave you the sensation it would swap ends , then when you actually got your teeth into a bend it would understeer, this was not the car to give to
@paule78 .
Changing the rear springs has produced this sheet with my long suffering Brother in Law sat in the seat for the duration and for the sake of slightly better science
Sorry about the quality of the pic , but you will note several changes, most if not all positive
The Road test revealed a more benign car which is much more neutral, but actually has a better front end. This while not perfect is close enough to return to it's owner for testing and appraisal an no doubt the production of a list of things to do.
This is the reason for measuring things once you have endured the pain of doing it a few times you can get where you want to be much quicker with subsequent attempts. when I first set up my 8 nearly 20 years ago. it took closer to 12 sheets to get something close to this for balance, and if you've read the Dauphine thread ..........Well you know don't you.
If I had not wrong footed myself with the wrong back springs thinking they were the right ones that are in now, then the 2nd sheet would have been the 1st sheet and I would have been a Legend (in my own mind anyway) but this is real life and I'm never that lucky
Definitely not much more soon......... bet you're glad.............
