aly b
bought this car over 10 years ago , used to be my everyday driver but was getting rough , had it painted and modified the c1j , carb mods , t25, grill mount , water injection and lots more , my mate was building a clio track car (f7r) and said "you should build one of these " so i then thought , yer i should , lol that was three years ago and hasnt turned a wheel since .
just back from paint
outside northampton motorsport , just before i took it off the road
clj
[BREAK]
empty engine bay
engine built up as follows , f7r 200 block,wire rung, velsatis pistons and rods , 172 crank lightend and ballenced, 16v flywheel lightend and ballenced, willy head and cams, pullys, f7r sump with oil return weled in, new cam belt and waterpump , all new gaskets etc , oil sandwich plate,4 paddle clutch , willy gearbox, renault 5 drive shafts.
all built on the subframe, powdercoated subframe , bottom arms , anti roll bar , engine mounts , willy rad kenlowe fan ,oil cooler
4 paddle , and pullys
willy head
external wastgate (not used ) and oil cooler
21 turbo injectors
21 turbo injectors
brakes powdercoated
21 txi brake disks with caliper extentions , avo coilovers
wheels powdercaoted, wheels tried on to see if they clear brakes
very close
chip, to suit 2.0l turbo running 15 psi on 802 injectors two bar map sensor
powdwer coated ecu , cover , mounted inside scuttle tray
hey ive seen this car elsewhere, mint, looks clean as feck...
theres a different way to insert pics into the project report, im going to work on a guide to doing it, its handy when you get used to it...
really love the car though
where else have you seen it mate ? its not been out for a while . yer was a strugle to upload the pics .
[BREAK]
new cross member
charge cooler rad fitted.
2.5 inch ehaust , stelthy tailpipe
under the back
under the front , 2.5 inch down pipe
stelthy looking 2.5 inch gloss black tail pipe , (dispite not looking like its in the middle i can asure you it is its just the photo)
renault 5 gtx engine mount
blanked off the electronic dipstick
hydraulic adapters fitted to the sandwich plate
one way valve for turbo oil feed (1 bar)
hyrraulic 90 deg adapters fitted to fuel tails
hydraulic addapters fitted to presure reg
hydraulic adapter fitted to turbo oil inlet , just gotta get my hose man to make the hoses up now
[BREAK]
starting to bend new fuel hoses
new fuel lines bent and primed
painted black
charge cooler fitted.
brand new water pump
as it is at the moment
the little header tank , not sure what to do with this yet.need to do my home work , on how is best to pipe it up , all ideas welcome
[BREAK]
new fuel lines with weld on clamps
where the fuel lines come up into the engine bay, and adjustable fuel pressure reg
[BREAK]
extreemly short bottom hose
silicon hose 80mm-51mm
volvo 440 alternator brackets
oil cooler piped up
ptfe lined fuel hoses
ptfe oil turbo feed
[BREAK]
oil catch tank
header tank in the original 5 turbo place , hoses made from straight silicon
turbo water pipes bent to suit
roughly were the airfilter will sit , should be nice and cool in there
short shift, changed the bit in the car to but havnt got a pic of that
prety much how it will all look
wheels with tyres toyo t1r
i'm not certain where i saw it, saw a pic of it on another forum i think, it caught my eye
i know the feeling, lots of knuckle skin and blood drops go into those cars, especially in the bay
also this "northampton motor sport" place looks awesome, is it just renaults hang out there, i want in!
cant get my head around this , i have uploaded some more pics from my photo bucket but they are showing on here as links not the pics , why is that?
did you put
at the end?
Interesting arrangement with the front crossmember there. Not sure I'd call it 100% structurally sound but I guess it does the job. For now.
believe it or believe it not , that piece of steel i put in was stronger than the bit i took out , didnt trake any cutting at all
well i would have said it was stronger , a lot thicker ,it was a piece of angle so the structure of that is stong , and to be honest i wouldnt say the strength in the front of a 5 is from that would say the subframe is were the strength is
that is a nice engine build. The brakes look good, Is this car on the road now? I want to see it on the road!
no mate not at the min , its how ya see it in the latest pics , need a few more bits , a chargecooler, four tyres, shocks re-building at the front , oil cooler pipes (chap coming this week hopfully) ,gotta wire it all up , and am also going to make some new fuel lines while its up in the air. them MOT time
thats mint mate , always a nice car from when i used to see it , glad you kept it mate , you not on rtoc any more ?
