For Sale Renault 21 turbo parts
Alright Haz
I'm after a few bits for my 21 turbo just wondered if you had what I need mate which is a heater motor resistor and blower - I have a K reg 21
Thanks
Jonathan
Iam after the fan/blower and the heater motor resistor mate if you have the both then great just let me know how much you want for them and if you can post them to me in Sunderland
You can get the resistors new usually, search for Valeo 509279.
Please dont throw the old one away either, I bought the thermal fuses to repair them as its always the thermal fuse that blows so if you send me the old one I should be able to fix it :)
Thanks for that mate I will have a search for that now and keep in touch - did you have a blower amongst your spares
Renault won't change parts if they dont have to, far too tight.
Sent from my LG-H850 using Tapatalk
Part numbers don't cross sadly, I was hoping they would.
If I could find one cheap enough I would buy one and use the R21 plastic base to see if I could fit the new motor to it - much like using the Volvo S60 washer pump I talked about the other night 'if you can make it fit', but almost a hundred quid for a 50/50 gamble is a bit much for my tastes (when mine works fine at the minute).
Yes, list updated a few days ago. Which coolant hoses, full set?
Hi again, the hose I actually need is the short one from the electic aux pump to the turbo, its L shaped and around 400mm long. plus as I mentioned the pump as well. Many thanks.
Thats actually straight when you take it off, but bends through 90 degrees on the car when fitted. Awkward to replace as it has a big fitting on the pump and a smaller one at the turbo, IIRC it drops 19mm to 10mm-ish.
Hi yes thats the one! Maybe you could let me know postage costs and I could paypal you the money for hose, pump and p+p.Many thanks indeed.
I'm sure I've both, I've a few parts to get out so doing it all on Sunday, will get pics and postage cost and get back to you then
I'm sure I've both, I've a few parts to get out so doing it all on Sunday, will get pics and postage. Isnt and get back to you then
Thanks, have you sorted these parts yet, I can sort you payment when your ready, many thanks again.
