For Sale Renault 21 cheap spaires or repair.
Iain Pearson
Renault 21, 1.7FS, 1989 F reg, spares or repair. This vehicle was used for 1 year about 7 years ago then put in the driveway when I got another car, had many new parts fitted before it was used, the cylinder head was reconditioned, new clutch fitted, new brakes, exhaust, all bearings/bushes on the back axle, new headlight new tyres. The engine was started about a year ago and has not been run since but should start with new fuel and a good battery. It would need very little work for an MOT.
The interior is complete and in good condition, the body panels are in good condition, some minor mark/dents, the paintwork is poor in places with the lacquer flaking.
I was looking at scraping this vehicle but would rather have someone get some use out of it or used for spares. Located in Airdrie, Scotland ML6 8JD, £80 or any reasonable offer considered. Buyer must collect.
Cheers Malky.
Not for me but might be someone another website I frequent that would probably love it, any pictures or contact details and then would it be ok to post it on there on your behalf?
I will take some pics this week and may try to get it running, it has not been started for about a year but I am confident it will start with some new fuel. Don't mind where it is posted just want it to get used again.
Cheers
Malky
I have taken some pictures but can't add them. I tried to start it but the spade connector on the starter motor has come loose and I need to get under the car to fit it, all the electrics are working, lights, indicators, dash lights, etc. The car needs a clean, N/S headlight is corroded and need replaced, O/S headlight was renewed. some rust spots that could easily be repaired. The engine is turning over manually, I will fix the starter connector and get it running some time this week.
Cheers
Malky
I had a look at starting it tonight but the solinoid would not kick in so will try at the weekend to rmove and fix it. If anyone wants any pic sent send me a message.
Cheers
Malky
Got the car runing today and checked it over, sills need some welding and a bit at the bottom of the rear wheel arch, exhaust is solid but blowing at the manifold ring seal, discs will need rust cleaned of them, runs in all gears and all electrics work, radiator fan kicks in and engine runs okay. Mileage is 133000.
Anyone wanting pictures email me at [email protected].
Cheers
Malky
