Hi guys,has anyone had any issues with brake servos failing and causing bleeding issues?
We have a rally car so one line to the rear,x2 to each front brake,new calipers,rears are citroen bx bigger cylinder on 21 hubs again new.
New master cylinder
Load valve deleted
Symptoms are no pressure a big click in the servo when depressing the pedal,we've tried pressure bleeding and still no luck,running out of options nothing else we can change.
Maybe fault new master?
Or is the servo causing an issue?
Cheers guys any help is appreciated
New master cylinder
Load valve deleted
