G
Guest
Any idea how much it'd cost me at a garage to have the ABS pump removed, master cylinder replaced with a non ABS master cylinder, and new brakes lines to front and rear following the existing path of the old brake lines (not just gashed in anyhow)?
Or, do you think a complete brake line novice like myself would be able to do it? Bearing in mind i've got no kit to enable me to bleed brakes, no kit to shape the pipes, etc etc etc.
Cheers
Cheers
