RSTuning
Just a small update from today on the Discovey SVR, I ended up removing the passenger door on both cars to get easier access to the engine loom connections as they go into the car behind the glovebox.
The SVR loom, fuel lines, ABS pump, master cylinder, coolant lines for the matrix, AC pipes and wiper motor are now all fitted to the discovery! I had to swap the wiper motor last minute as the connection was different on the disco.
Just a couple of heat shields to go back on and I can get the engine and box in!
(Feed generated with FetchRSS)
Continue reading...
Continue reading...
