Yep, same thing happened with mine 6 months ago.
The points on the rear cluster connectors seemed to have oxidised. I simply cleaned them up and it's been fine since.
Sound like the same thing that happened to mine. It's got to be the rear left unit as a whole (not bulbs and not fuses). I was surprised by the level of corrosion at the contact points when a removed it. Bit of emery paper did the trick. French electrics eh? [smilie=bom.gif]
Good luck!
Good luck!
