Haz
Its been a while but I'm once again on the hunt for info regarding europacup and super production engines. I've had a quick look through archives and on google etc but only really uk sites. From pictures you can the the inlet and exhaust manifolds differ, prob have a larger throttle, the turbo is larger as is the exhaust system, standalone ecu and the injectors must be bigger. I've been told the compression ratio is dropped from 8 to 7.5:1. They have steel liners so I guess boost is high, 2bar+, and a steel crank, so presume they rev high, 7k+. Power seems to vary from 300-450bhp.
So, regardless of the ancilleries surrounding the engine, and the rest of the car, does anyone know the engine specs either first hand or from a reliable source? Cams, valves, head work, pistons etc etc.
Modern day tuning seems to be approached alot differently than back in the day so I don't think it's worth trying to replicate, more curious as to how they flow so much better than stock engines.
Opinions please.
Opinions please.
