Megane R26 coil pack order please?? Rough idle & engine vibration after spark plug change
jpmad4it
Hi all,
Please can anyone confirm the coil pack order on the Megane R26? I had my spark plugs changed last week but I'm not sure the mechanic took notice of the order of the coil pack. The car is now vibrating like mad and I can feel it through all the pedals, even when idle. The higher the revs, the more vibration I seem to get.
The problem has just started since I had the work done,....the car was fine before.
I don't really understand the numbering system which is commonly used e.g. 3 4 2 1 etc. So I might need a dummy explanation
If I upload a photo of the coils on my engine could you guys confirm if any of them are in the wrong place?
Any help would be greatly appreciated.
Thanks
Jp
Ok I'll do that tonight.
Where about's is the TDC located in the engine bay? Does it need removing to be cleaned?
EDIT - and what's the best thing to clean it with?
Getting a vibration through all the pedals, which was much worse in the hot weather we had a few weeks ago. And it was much worse on acceleration.
The idle is just very rough and clunky. Getting a bit of exhaust cough too.
All of these symptoms are worse in hot weather.
Could be a mixture of TDC sensor, injectors, engine mounts. God knows :negative.gif:
Got the NGK sparks in now, and its the same.
Next job is to clean the TDC senor :-)
Disco test complete. Sounded much worse with each plug unplugged. So I guess it's not one of those which is faulty.
Need to get the TDC sensor cleaned next. Think I'm doing it on Saturday.
Hi again. Just had the Toxic Fume Filter System Warning Light flashing on my dash.
I've read that this also points to the injectors, is that right? Thanks in advance.
Edit - is it also ok to get these ANSU cleaned instead of fully replaced?
I had mine ANSU cleaned. Request a flow report.
The cost was £50 , new ones were £160ish I think
