James5
Evening all, for some reason I bought another meg 225 I really don't know why was more of an impulse buy.
Anyway the car was a none runner when I got apparently the fobs didn't work or start the car and it wouldn't crank. So I fitted a new battery to the car when. I got it and hey the fob unlocked and locked the car and the car cranked (did not start). Also noted that I had keyless entry which was unexpected.
Anyway so I done compression test all 4 perfect, checked fluids and again all good. I then removed the sparkies and replaced with new OEM ones, I also replaced the coil packs with brand new, car still didn't start so I thought let's check fuel to rail and yep loads of fuel. I bought a brand new OEM tdc, and brand new OEM injectors and guess what I still have the same issue.
The car cranks over coughs then dies anyone have any idea's? I am thinking it's spark related as the spark plugs are wet, I have removed coil pack 1 with spark plug and it arcs fine dueing cranking I'll try the other 3 tomorrow.
Do we have a wiring diagram for a 55plate 225?
